gomango392
So it was brought to my attention that I never posted a write up on doing the OEM LED to SS3 fog converaion. stupid me! anyways here's the link to the full in depth review on switching your truck from LED to halogen to be able to run the SS3s.
Here's the link to the SS3 kit- SS3 LED Fog Light Kit for 2019-2024 Ram 1500 (non-LED)
And heres the link for the OEM LED trucks (if you dont want to do the halogen swap)- Stage Series Fog Pocket Kit for 2019-2024 Ram 1500
Also remember to use code gomango392 at checkout on the Diode dynamics site for free shipping on your order, works for any product on there!
OEM Part numbers needed for the swap:
Part number for the brackets: 68403915AA
Part number for the bezels: 68318117AB
Remember, the brackets come in pairs (RT/LT) and same goes for the bezels. The part number I linked for the bezels is for trucks with parking sensors (FYI).
the wiring is all the same, both halogen and led trucks are H11 plugs so no worries there! After you swap out your oem bezels and brackets, the wiring is all the same and it becomes a plug n play kit from there.
Now diode dynamics does make a plug n play kit for OEM LED trucks using 2 SSC2s (2 per side, toral of 4) but only in sport level output (unless you buy the lights seperately if you wanted to go with the pros, which i advise doing), but to me, the single SS3 looks better and will have much better output.
Here's a comparison between an SS3 pro and the OEM LED fog.
