OEM 22s vs 22x10s
Bigdumps
Hey, maybe someone will know better.
I recently added 2" spacers to my oem 22 sport rims with 285/55r22 Mickey Thompsons Bajas. I liked the look of added the fender flares and stance.
I've ordered some 22x10(something similar to the Cali summit)rims with -18 offset.
Factory rims are +19 offset and 9 wide, I believe. So that would be roughly -30mm of offset with spacer and rim accounted for.
I'll be removing the spacer before the new rims go on obviously.
With the new rims width (+1 inch) and offset(-18), would my stance be the same to current, and will it be rubbing my UCAS? Does the rim width split between inner and outer? I've confused myself.
Bigdumps
Pictures of the new rims, and current set up with factory rims with 2" spacers.
CHeYeNNe71
Sh*tcagoland, IL
mplaramie
Here is my 23 with 22x10 -18's with 285/50/22 tires. Should give you a good idea of the poke. No fenders flares.
Bigdumps
Bigdumps
Had the new rims mounted and balanced.
