North country edition
Rdubs20
Does anybody know if the north country addition comes with the 1 inch suspension lift?
If you add the 4 corner air suspension to the north edition package are you then looking at a possible 3" lift (1" from North + 2" from the 4 Corner)?
Or does the 4 Corner then replace the 1" lift?
The air suspension does not give you a 2" lift. It CAN lift up to 2" when in OffRoad 2 mode, but the speed is limited to I believe 25 MPH. If you have air suspension plus the offroad package, then you get the same 1" of lift as a non air suspension, but as a result you lose the OffRoad 2 mode and can only go up to OffRoad1
^^^This^^^
The ORP with the air suspension really only gives you Extra HD shocks, the air suspension just simulates the 1” lift by having its normal setting set at 1” higher than non-air. But you top out at the same lift whether you have air or non-air.
