Noise in rear
my first 2500
Hey folks I'm new here so maybe someone can help me out .
I just bought a used 2022 2500 reg cab diesel out of province . When it was delivered I noticed a noise in the rear whrn i hot a bump and the rear flexes that almost sounds like a tailgate rattle . I removed the tailgate and the sound is still there . I got underneath and with pry bar tried to see if any movement in bushings, they were all solid.
Any suggestions?
Any suggestions?
ya go here
this is a 1500 forum
you have a 2500 which has a different suspension.
Check to see if the spare tire is snugged up tight and fully inflated.
Could be the air vents on the back of the cab. See if the noise stops by keeping the windows up with the fan on using outside air, this will force the vents open and they won't be able to flap around
