No route/map display in instrument panel in front of steering.
w22035
Anyone met this before or any settings ? I used to have route/map navigation displayed in instrument panel in front of steering. I thought last week I got Uconnect updated and today I noticed there is no route/map display in instrument panel anymore. It is just showing black/blank as attached
I realize this is somewhat old but most of the display problems can be solved by simple reset. Ask the dealer how to reset the display.
Set appointment with dealer.
Yes, whenever I press the reset option "clear user data", the map is reloaded and appear in the cluster window. But after sever times startup, its gone again :-(
I do not have an answer to your question and hope the dealer can help, but I do have a question for you. Doing 90 MPH, how in the heck did you get MDS to kick into ECO mode? Downhill?
It doesn't really make any difference what speed you're driving 40 50 60 90 if you take your foot off the gas pedal it'll go into eco mode.
I Have the exact same problem. It came after the latest firmware update. If a soft reset uconnect by holding power for 20 secs it fixes it temporary until I turn off the truck. Any permanent fix??
No, visited dealer 3 times and replaced radio already, nothing helped. I believe it comes from the latest software and no way to fix it right now. Anyway, I escalated it to RAM and they asked me to bring the car back to dealership and they will work with them to have it fixed. I will see even I have no hope.
Good luck!
Update : get car back from dealer, no surprise. They can not do anything, ask to wait for next soft update.
Try changing background theme (somewhere in settings). I read about that somewhere. My map came back with that and has not disappeared since. Some updates since then too so maybe that helped.
