No Drill Center Console MOLLE Panel
boogielander
Overview — What This Is​
MOLLE panels mounted to center consoles don’t need introduction. You already know what they are and what they’re for. The problem has never been the panel - it’s always been how to mount it properly.
Up until now, every solution on the DT platform required drilling into the console. Do a quick search and you’ll see it.
This fixes that.
This panel is designed specifically for the Ram DT platform using factory mounting points + dedicated brackets, instead of self-tapping screws into plastic. The system uses the factory 10mm mounting location to generate clamping force and tie into actual structure. Goal is simple:
  • secure mounting
  • no permanent modification
  • OEM-adjacent fitment
The Problem With Existing Setups​
People have been running universal MOLLE panels on these trucks for a while now, but they all share the same issues:
Drilling into interior
Not everyone wants to put holes into their center console - especially if:
  • the truck is leased
  • resale matters
  • or you just don’t want to commit
Load on plastic
This is the bigger issue.
All the load - panel + gear - ends up concentrated on:
  • thin plastic
  • small drilled holes
That works… until it doesn’t. Add vibration, weight, and time:
  • holes start to oval out
  • mounting loosens
  • panel starts to move
Short-term solution. Not a long-term one.
Design Approach — Why This Exists​
Per typical Boogielander way of doing things, this wasn’t designed to “kind of work.” It was designed to fix the mounting problem properly satisfying the two principles:
1. Match the vehicle
  • Panel follows console geometry
  • Sits flush instead of fighting the surface
2. Use real mounting points
  • Factory 10mm location is used intentionally
  • Brackets spread load across a larger area
  • Bolt preload creates clamping force
That clamping force is what holds everything in place.
Not screws. Not plastic. Not hope. Not dreams.
Mounting System — How It Works​
  • 5052 aluminum brackets
  • Factory mounting point (with replacement M6 × 45mm bolt)
  • Secondary support from bracket interface
When tightened, the panel is pulled into the console and held under tension.
Result:
  • minimal flex
  • reduced vibration
  • load transferred into structure, not trim
Why No-Drill Matters​
You can drill. Plenty of people do.
But everything comes with trade-offs:
  • Drill → permanent
  • No-drill → reversible
This setup is for people who:
  • don’t want permanent modification
  • swap gear / setups
  • care about keeping the interior intact
Included Contents​
  • Trim profile matching 5052 aluminum MOLLE panel
  • Mounting brackets
  • MOLLE nuts (1" × 0.75")
  • Full hardware set (M5/M6)
  • MOLLE spacers
  • Replacement bolt for factory mounting point
  • Optional storage box
Nothing extra. Nothing you need to source yourself (unless you choose to drill then you’ll need to find the spacers and bolts).
Intended Use​
Interior gear mounting. That’s it.
  • radios
  • med kits
  • tools
  • EDC
  • holsters
If you’re trying to hang body weight off this, you’re using it wrong and I cannot help you.
Installation Steps:​
Not complicated, but also not something I’m going to hand-hold step-by-step.
Basic idea:
  • mock it up first
  • attach brackets
  • install front to back (hook → press → slide)
  • adjust with spacers if needed
  • tighten everything once you’re happy
Take your time, don’t overtighten hardware, and you’ll be fine.
Why Choose This Over Other Options​
If your priorities are:
  • clean fitment
  • no drilling
  • rigidity under load
  • removable setup
This makes sense.
If you’re fine drilling into plastic, then do that.
You can even skip the brackets entirely and run spacers with longer bolts — same as every other setup.
Plus, you know Boogielander – I only do things the correct way. This is doing things correctly.
Available Options​
  • Black powdercoat
  • Raw aluminum
  • Single
  • Pair
Final Thoughts​
This isn’t trying to reinvent MOLLE panels.
It just fixes the two weak points:
  • bad mounting
  • poor fitment
By using factory structure and proper geometry, the panel stays put under load — without turning your interior into a permanent project.
