Nitto Terra Grappler 2 305/45 R22 on Stock 22inch Rims - 2021 Ram 1500 Night Edition Limited with Air Suspension
Discraftpro
I am including some pictures for those looking at this tire. I chose it, because it was the biggest Grappler 2 (305/45R22) I could run without rubbing. Bad news, there is still a slight rub at full lock coming from the passenger side in reverse. I am including pictures for others to judge the look. This was in aero mode, but it also rubs in normal mode.
Looks good. How does it ride?
Trying to figure out how to add some sidewall without going E rated...
Rides fine. The tire shop only filled to 40 psi air. The guy doing the work said that it is what he runs his tires on and it keeps the ride smooth and helps with wear. Not certain that I am buying that but I am willing to try it for a while and see how things go.
How is the ride quality so far? I have the exact same truck and thinking of going 305 but air pressure charts say the pressure to be 33psi for that size when calculating the ratio from stock 36psi. My problem is if I have to keep that low then it doesn’t give me any extra rubber height due to less air. What psi are you running? This pressure was from calculation from tire101 site.
The ride is the same., and as I stated above I am running 40 psi.
