Been lurking for a couple of weeks after getting a Ram earlier this month. Picked up a "used" 2023 Big Horn crew cab 4X4 with the 5.7 eTorque, 6' 4" bed. I say used as it went through 5 different entities before it came to me with 53 miles on the clock! Already planning on several upgrades already, the 7" EVIC is already on the way. I've got AlfaOBD, a usb OBD cable, and an ECRI bypass, So I went out and wanted to connect up and see if I could connect into the truck, pulled off the kickplate and found a security bypass cable zip tied and tucked up over the OBD port! I don't know if that's a good or bad sign but......... I had to order a different OBD cable, the one I have has the HS / MS switch I doesn't want to play well!
![adapter.jpg adapter.jpg](https://5thgenrams.com/community/data/attachments/184/184699-b805395e9df1b4a3702eb147f1184291.jpg)
![Ram.jpg Ram.jpg](https://5thgenrams.com/community/data/attachments/184/184698-2667de0cadf9ae96e73935a5b451a9f2.jpg)
