Velocity
I put a set of 22x10 Axe Off-road Chronus with 305/45/22 Venom Power RT+ tires. Tires are right around 32 7/8” tall. Wheels have -19 offset. They stick out about an inch past the fender flare. Ride is a bit harsher than with the factory setup but I expected it to be. They are louder than I thought they’d be for sure. As of right now I have the stock ORG suspension on the truck. I have Rough Country 2” loaded leveling struts coming in to hopefully make it sit level. With the stock suspension the driver side tire barely rubs on the small “mud flap” looking part on the backside of the fender well. I could trim it now and there would be no rubbing but I’m hoping the leveling struts will get me high enough to clear it.
