New Tow Mirrors installed...cant get full functionality
codyjm28
Hello, I have been scouring the internet for answers, no luck. I still cannot get my reverse guidance lights to work after installing tow mirrors. Turn signals, power fold, adj. arrows change when mirrors are up/down, but no reverse guidance lights. I have read you need to turn on cargo light, in reverse, for them to turn on. No dice. I have made "tow mirrors present" in alfaobd, and turned on trailer reverse guidance, but i dont think that is for the lights. I think that is for the trailer reverse assist knob which i dont have. Any ideas? Using android phone for alfaobd. Thanks!
Hello, I have been scouring the internet for answers, no luck. I still cannot get my reverse guidance lights to work after installing tow mirrors. Turn signals, power fold, adj. arrows change when mirrors are up/down, but no reverse guidance lights. I have read you need to turn on cargo light, in reverse, for them to turn on. No dice. I have made "tow mirrors present" in alfaobd, and turned on reverse guidance lights. Any ideas? Using android phone. Thanks!
Not sure if the HD Rams are similar enough to the 1500s, but they say there is a button on headlight switch for the. If you didn't replace the headlight switch, then maybe they won't work?
From the other threads I have read, there should be an option in radio to enable them, but I cannot get that option to show up even after multiple hard resets. I feel there is an option i need to turn on in alfaobd but I am not finding it.
Thanks for posting the settings info. I've got a set of tow mirros on the way to swap out on the current vehicle. Just saved me some daylight hours and likely sanity.
Edit: Yep! Had to load current vehicle in Alfa, then forced it over to the 2020 2500. Selected those options listed above and everything worked perfect.
