Need some help-oil leak
TAroux
Can anyone help me out? I’ve had some oil leaking slowly checked the filter everything seemed fine but looks like it might be coming out of this area? Not for sure what this actually isD5BF845F-3D8B-4116-AB43-BFAF4CF4BB60.jpeg
is it motor oil? Just gotta follow the oil spots until you find where it’s coming from, or if it’s under warranty just drop it off at a dealer, that would be the easiest option.
Look at the frame side of that rack mount bushing - is there anything leaking into the bushing from above?
As mentioned, highly likely it's residual oil that dripped when it got it's last oil change (from the oil filter change specifically) and they missed wiping it off, then it rolled to the bottom of the bushing.
Go ahead and wipe it clean, then drive it a while, if it comes back then you know there is an issue somewhere, but likely not an issue.
