Need help with Westin HDX 3 step nurture bars
w69dy
Has anybody installed the Westin Automotive Products 56-534705 HDX Drop Wheel Nerf Step Bars. Having a little bit of an issue with the 3rd step mount. There’s an L bracket that suppose to be install on the frame area but I can’t figure out where. Stand by for more pics.
I only got the 2 step version. Mine had 3 brackets per side.
Each position was easily found by the sets of 3 studs under the body.
The brackets are all position sensitive. There is a front, middle, and rear bracket per side.
Mine have 4 brackets and the rear one is PIA!
I know their instructions are less than stellar.. good luck!!
I figured it out. They marked one of the brackets wrong smh
Good luck, mine are showing rust after less than 3 months!!!! Put on at about 200 miles am at 1350 now. What a waste
In my prior experiences with Westin, their customer service was great, so definitely reach out to them and see if they'll fix that. They certainly shouldn't be rusting in less than 3 months!
B
Ugh. I've got those showing up here tomorrow, so I'll be interested to see if they're also marked wrong. Do you remember which one was marked wrong, and how it was marked?
Thanks,
B
