Csjumper2003
- Dec 24, 2021
I have a 21 Ram 1500
I have the new 6aux switch installed and working.
I have 2 questions.
1st : if I have 2 air horns that have 2 small compressors it is setup with 2 relays to be used. With the aux switches it only has one relay for the trigger. I am thinking the 2 relays to give the small compressors enough wattage and amps for the horns. Anyone know how I can wire these ?
2nd :
I am running a 12v aftermarket front camera. I am a little unfamiliar with the camera but told they work good. I see on each end of the camera there is a red positive wire which I assume is a positive
The question is do I need to connect the positive to the battery and then if so where would I connect the other side behind the radio.
Also any pictures for the plug for a Uconnect 4 plug would be awesome
I have 2 questions.
2nd :
