Need a Phone Mount? We have Options with our Cravenspeed Gemini Mounts - only $50!
NGEN
5thGenRams Vendor
5thGenRams Vendor
Conroe, TX
If you are looking for a quality phone mount to use in your 2019-2024 Ram 1500 DT, we have you covered!
Cravenspeed Gemini Phone Mount with a Magnet, Magsafe or Scissor Base (2019-2024 Ram 1500 DT) - $50
Here are the details:
How to Make the Best Phone Mount
Our approach to designing the best vehicle phone mounts is centered around 3 core principles. Firstly, we are very skeptical of most universal fitment mounts on the market. Things like suction cups, vent clips, or stick on mounts aren't designed specifically for your 1500. They can fall off very easily and don't keep your device safe. Our preference is to design mounts with specific vehicle fitment. For the Ram 1500, we have designed a steel bracket that installs on the left side of the utility pocket that is found at the top of the center console. This provides an extremely secure and easy to access attachment point and ensures that our mount can never fall off.
Rapid Attachment
Device attachment to the mount should be fast, easy, and secure. Our magnetic attachment system is the fastest and most convenient method of attaching a device to the mount.
Adapts to You
The last part of the puzzle is you. Humans come in all shapes and sizes. Thus, our 1500 phone mount features a 360 degree articulating ball head allowing you to have complete control over the position of your device.
Bonus Features
With the above principles in place The Gemini creates a secure, convenient, and comfortable space dedicated to your phone. In the 1500 navigation through your phone is much easier with the screen much closer to your field of view. The Gemini makes using your phone for navigation a breeze. Even with CarPlay/Android Auto you can more easily use your device to type in addresses or search for a lunch spot.
Quality Guaranteed
All of our Gemini mounts are machined and assembled in the USA and come with a lifetime warranty. We put a lot of effort into designing mounts that are easy to install and require very few tools. By following our detailed install guide, anybody can install a Gemini mount in their driveway. All hardware necessary to install the mount and attach any device is included.
Magnetic vs MagSafe vs Scissor
This mount is available with three different styles of device attachment. The first two are magnet based. Our Magnet/MagSafe attachments are compatible with any device and offer the ultimate speed and convenience. Phones or cases equipped with MagSafe are directly compatible with the MagSafe attachment. All other devices require the use of an included adhesive backed metal plate. For phones with Qi functionality, the MagSafe version is the best choice. This version comes with a ring plate that will not interfere with the wireless charging feature. Any non-Magsafe or non-Qi device can use either version, though the standard Magnet base is recommended in this case.
We also offer a scissor grip attachment for those looking for an alternative to the magnetic attachments. With this version, CNC machined billet aluminum arms form a spring loaded gripper mechanism. The soft rubber pegs gently and securely grip your device to ensure that it does not fall out. The scissor mechanism can rotate 360 degrees so the phone can be held in either portrait or landscape mode.
To purchase, click the option you want below:
Cravenspeed Gemini Phone Mount with Magnet Base
Cravenspeed Gemini Phone with MagSAFE Base
Cravenspeed Gemini Phone Mount with Scissor Base
