Need a looking for hard tonneau for 2025 Ram Limited 5'7" bed wth ram boxes.
mliskey
Does anyone know we're I could purchase a hard tonneau cover that will work on a 2025 Ram 1500 5'7" bed and Ram boxes?
Can you be more specific? There are several types of hard bed covers out there.
Hard tri-fold...
Hard roll-up...
Fiberglass...
I’m searching for a hard trifold bed cover for my 2019 ram 1500 limited with ram box. Any recommendations? I would like to stay away from the backflip. I heard nothing but problems about that one with leaks and stuff
I purchased and installed the Tonnoflip 4 weeks ago on my 2025 Ram 1500 with Ramboxs. It is made for the Rambox. It took me 1 hours to install and really like the way it fits and looks.
I paid $899.99.
I paid $899.99.
How does it do with weather? Any leaks or anything?
Thank you much appreciated. I will check it out. Does it come with a seal for the space between the bed and the tailgate?
Yes, they send gasket materials along in the box.
If you see my pictures, you will see I used the Black "D" shaped gasket. I just cut a piece to fit.
After you install the Tonneau it will fold up and lean against your cab light on the back of the cab. Be sure to install a piece of the gasket material where the tonneau would rub against the light.
Yes, there is one on each side that extend and hold the lid open. On each of those rods there is a button you push that locks the rods into place.
It is a very nice setup up. When you done using the rods, they fold down into place.
Roll to the bottom of this weblink and you will see the truck years to pick from. You need to make sure you have the 5'7" bed.
When you're on the website, makes sure your screen is 75% is less in size so you can see the order button
Ill have to check them out, I was set on going back to either a Bakflip (had one years ago) or Undercover but I also heard bad quality w/ Bakflip nowadays.. guess that happened once Realtruck bought them out.
When did that buyout happen? We have a bakflip on our 2020 Limited that I installed the first week we had the truck. We haven't had any issues with it in the four and a half years we've had the truck.
I’m not really sure I only really took notice when they seem to push Bakflip/undercover products more and sometimes put those on sale. They own Retrax/Gator also,
I think it happened within the last year.
I just installed a Truxedo LoPro roll-up cover on my 2025 Longhorn.......nice fit, easy to install and set me back about $540. Haven't driven in the rain yet, so I can't tell you if my rear bed storage area is water tight. I don't think ANY tonneau cover is 100% water tight.....just too many gaps/openings with the RAMBOX option.
This is definitely the case. Some of the openings in the tailgate area are pretty large.
Yep unless you go fiberglass hard cover probably gonna leak at the tailgate area. You can seal it somewhat but I doubt it would ever be 100%. Put important items in bins or waterproof bags and/or toward the front.
