My Towing with Travel trailer measurements with Air-LiftHD - e2 antisway WD (1000lbs) bar - 2019 Ram Rebel (stock) minus airbags
YngwieL
Springfield, IL
Figured I would post this incase somebody was looking at something similar setup wise.
2019 Ram Rebel 4x4
Travel Trailer = 2021 Flagstaff microlite 25BDS - dry weight=5500 lbs. - GVWR 6785
Tongue weight 625 lbs.
Hitch Height 24.5"
Fastway e2 Weight Distribution w/ 2-Point Sway Control - Round - 10,000 lbs GTW
AirLiftHD airbags with 5 lbs. of air at setup and when not loaded.
Measurements height (top of fender flare)
With Nothing on the Hitch = F: 41-7/16" R: 43-1/16"
Only the Travel Trailer Weight on the Hitch = F: 41-14/16" R:41-15/16"
Halfway back point for front = 41-10/16" min.
Weight Distribution Hooked up = F: 41-5/16" R:42-8/16"
when I added 35 lbs of air into the air bags= F:41-7/16" R:42-14/16"
front is back to its original height of 41-7/16", Rear is at 3/16" lower then original height of 43-1/16"
I used the top 2 holes on the bracket that mounts to the travel trailer, and have 6 spacer washers in the hitch head.
fyi: I used only 16th of an inch to keep it all the same
