SilverSurfer15
- Jan 21, 2019
The dash stays around 12-12.5, hand cal is usually about 1 mpg less. This is for straight up city use, plus like an hour of idle time per tank because it’s always 100 degrees here. So basically worst case scenario mileage unless you drive inside a ‘real’ city and are stuck in brutal traffic.
On the highway it seems about 13 but that’s kind of a guess. It doesn’t really like to go 61-68 mph, just with the gearing and what not. So if you run it at 58-60 in the right lane, maybe as high as 16 if it’s flat but probably 14-15. It will run 70-75 better than I thought it would, once the rpm gets high enough in 8th to actually hold the gear. (Thats the issue with the 60mph area). Probably does 13-14 at 70 if it’s flat. If there’s rolling hills, forget about it lol. I wouldn’t want to drive it all the time in say PA on the highways where even a stock truck has to let it rip to keep up speed. It would be horrendous and suck to drive.
This truck around town in same scenarios would barely bust 13 stock And really never averaged more than 16 on the highway at any decent speed but I don’t drive enough on the highway to really care about the loss there.
