My headlights
ChuckBRam19
For some reason my headlights won’t turn off. Even in the off position.
Yes but does that affect the headlights?
The DRLs are your headlights, just at lower intensity.
Daytime Running Lights (DRL) — If Equipped
The headlights on your vehicle will illuminate when the
engine is started and the transmission is in any gear except
PARK. This provides a constant lights on condition until
the ignition is turned OFF. The lights illuminate at less than
half of normal intensity.
Rick J is correct, but you can turn them off in the settings in Uconnect if you want to.
