Motofab Level help
Jollyroger0612
After installing one side of the level I realized the instructions said to use the provided nylon nuts to secure the spacer to the strut. I used the factory nuts to secure the spacer and the provided nylon nuts to instal the strut back into the truck. Is this going to be an issue? Do I need to remove the strut again to swap the nuts around or should everything be fine?
