Mopar UCA
Woody284
I have spent the better half of the morning researching and reading threads about the 5100s, UCAs, (need them don't need them), part numbers etc. I know this has been discussed a lot but I am not finding what I am looking for specific to the 2025s.
I am not looking to get the Mopar Performance 2 inch lift kit in particular but, am interested in the Mopar UCA's in the kit. The reason being is I only use my truck for on road driving, and maybe driving across a field at slow speed to set a hunting stand. I do not offroad or do anything fast offroad. The Mopar lift UCAs of the past can be purchased much cheaper than the aftermarket ones and should suit my need of correcting ball joint angle just fine if I added the 5100s set at a 2 inch lift.
Some online Mopar sites list the kit that fits the 2025 Ram 1500 as part # 77072424AE which replaces 77072424AD, 77072424AC, 77072424AB, 77072424 of previous years. I found the Mopar UCAs (for the 2 inch lift) part numbers listed in an older thread (3 or 4 years ago) listed as 68323530AA, and 68323531AA. They can be purchased for $100 each or cheaper depending on which Mopar online parts store you look at. What I cannot find is if these part numbers are still true to fit the 2025 Ram (non ORG) or a listing of the UCA part numbers for the current 77072424AE Mopar Performance 2 inch lift kit with fox shocks kit. Also then the great debate of I need UCAs and I don't need them with 2" lift from 5100s.
My plan is to lift the rear one inch with Cargomaxx 35% Coils, and 5100s. The front using 5100s adjustable in slot 6 (2.2" lift) . The research I have looked at says they settle some so hopefully netting right around 2" after they settle.
My truck is: 2025 Ram 1500 -Bighorn CC - 4x4 - non org
That kit will work just fine.
Are you saying the kit will work just fine or the part numbers listed for the UCAs will work on the 2025s.
I do not want the whole kit as I think I can achieve what I am after for way less money. Just trying to figure out how to order the Mopar UCAs in the kit separately that are for the lift/level.
I believe it said all years through 26
