mopar fox shocks in leveling kit
jthorn75
does the new fox shocks cause the front of the truck to be lifted, is is adjustable? was thinking about adding these to a BDS 6 inch lifted truck rather than leaving stock?
Yes they provide the lift but are not adjustable. They are preload style like the bilsteins you just can’t change the spring perch location. To my knowledge you would gain 2” by swapping them out. I believe Porboy retained his fox shocks with his BDS lift you could try reaching out to him
I think it would be safer to use the bilstein 5100, falcon shocks, or a coil over at factory ride height unless you are looking to gain more lift in the front. With these adjustable options you could also opt for different height settings less than 2”
i just wanted to keep the set up uniform with fox shocks all the way around... but i dont want to make my 6 in lift an 8 in lift, atleast not yet lol
I don’t know if fox has that option for our truck yet. I believe someone used a fox coil over set up (that you can set at 0”) for a 2019 classic on his DT truck. That would be your only option for fox to my knowledge unless someone else knows more.
