It is an interesting piece of kit. Clearly not made by fca and doesn’t say Mopar anywhere on it. What they did was adapt a product by creating special rails that attach to the factory rails. It seems well made and is pretty easy to move and take off. There are a few issues. The divider mounting rails are obnoxiously large. The mounting system does provide access to your factory tie downs in your factory rails but greatly limits where you can position them. It also makes it much harder to actually get to them. My biggest issue is that the whole thing is mounted securely but rattles like a sonofabitch on every small bump. It’s a truck so who cares about rattles? Except this isn’t. It is a quiet smooth large luxury vehicle with a bed. Metal clanking all over the place isn’t befitting a proper Mopar accessory. I could probably duct tape shim all the points of contact but I feel that could inhibit the ability to easily reposition it. You only hear it with the windows open so it isn’t deafening. Since I could not return it because my dealership considered it a special order I decided to make it work rather than sell it. I used the included bungies to strap the sides to the bed tie downs. That took care of small bumps. Then with a thick solid bed cover I can no longer hear the clanking. It is a pretty nifty functional accessory that seems like it will last. I will post pictures of the mounting issues.
