Mopar #68446866AA for brake moan
Hemogoblin
Is this part number for one side of the truck only? So I would need two of them?
Thanks
I don't see a signature with your truck's details but assuming you have a truck still under warranty the dealership should install the break moan kit on both rear sides under warranty. On my 2019 they installed the braces and even gave me a loaner no charge.
I did it myself as well.
1 kit covers both sides and I did not replace the pads.
Works like it's supposed to and I have several thousand miles since without a peep.
Do you happen to have the torque specs??
Sent from my SM-G781U1 using Tapatalk
Is this the same part number for a 2020 1500 big horn 5.7 gas
I just talked with my local dealership about getting this kit and installation since I’m still under warranty. Dealership stated they have never heard of the kit and only thing they could do was use a spray and that’s not guaranteed. Such BS.
LOL and that is why I dont bother with them honestly. It was easy to put on (just be prepared, from what I recall the bolts are on there TIGHT) but the overall install is a breeze and worked great. No moans or squeaks since install.
bought mine off amazon and was super easy to install and it worked perfectly.. mine was making the noise when backing up in wet conditions..
