Mopar 2" Lift w/ Ridge Grappler LT285/60R20 on 2019 Laramie
Dagan
I have a 2019 1500 Laramie 4x4 with the stock 275/55R20s. I am considering the Mopar 2" lift and Ridge Grappler 285/60R20s with the hope of getting more clearance for occassional off-roading (fire roads, not rock crawling) without completely destroying highway performance or MPG. (I realize the Mopar kit is going to cost me a fair amount more than alternatives, but for me, maintaining the warranty is worth the hit.)
Does anyone have any thoughts they can share? I believe the 2" lift will accommodate (according to Mopar) up to a 295/60R20 without adjusting the offset, but I think the larger tires look a bit too stuffed for my taste and am hoping the slightly narrower tires will give better bad-weather perfomance.
Slide over to the suspension section of the forum and poke around. Several threads over there as well as a big mega one or two that will probably give you more info than you need. Good luck with ur mods.
