Mopar 2 inch lift question
wiendog
Does any one know if you can take the spacer rings off the front fox strut that comes with this kit and make it stock height.
Not sure the answer to that but that shock is meant to be used in a 2" lift situation. If you try to use it with a lower stance you might completely compress the shock before the suspension bottoms out which could cause damage.
If you are looking to replace the OEM shocks with Fox I would recommend giving them a call to see what they have available for stock/ORG height trucks.
Just my .02
