Memory seats and auto seat pullback stopped working
Wasy152
So it seems, at least I hope so, that the car glitched out and my seat memory and easy seat access stopped working. I checked the setting and have it checked for the seat to pull back for when I shut the car off. Also, the memory seat buttons literally don't do anything. Nothing shows up and nothing happens. I've tried to turn on/off a few times hoping it would reset and nothing. Was thinking maybe I can. Disconnect battery and reconnect it to reset the system? Everything else works fine including the auto step.
Not sure the entire sequence but you have to reteach the seats their home position by running the seat manually all the way to the rear stops.
I'm not sure what causes this but I had it happen a bunch of times when I first bought the truck but have only had it happen once in the past 2 years.
You are most welcome, glad it worked. Now to figure out what causes it.
I have a crate behind my seat with all my work safety gear in it so I think it's from when the seat feels opposition while trying to reach setpoints. I usually keep it centered so it won't interfere but we were moving the last time it happened and I had the cab jammed full of stuff.
