I have a 2019 ram 1500 classic that dropped a lifter and chewed up the cam. I ordered new non mds cam and lifters also I put the mds block off plugs in. my question is what do i need to do with the timing and where do i get the mds turned off at?
I believe it has vvt timing so i have read that it needs to be locked out. is there a way to drive the truck without spending the money on the tuner right now? would it run if I pushed the tow haul button every time i started it
You can still use vvt with mds locked out. Removing VVT would actually cost you power and drivability unless you're installing a huge cam like 230-250+ @.050's
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
