I have a 2024 Laramie just installed a maxtrac 2/4 drop and a spohn adjustable pan hard bar . Problem is at about 15mph I have a vibration both taking off and slowing down any ideas on what could be the problem?
1. Did you wait to tighten all of your suspension bolts after the truck was sitting on the ground (under load)?
2. Did you ensure that your rear wheels are centered, and not shifted to one side?
3. Did you get an alignment done on your truck after lowering it?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
