Manufactured scheduled maintenance intervals vs. your personal opinion
boldram
Gents, Changing spark plugs at 100,000 miles as specified by the manufacturer in the book.
I read a lot of posts where everyone has his own interval set in mind; 30, 40, 60, 80K miles.
I was wondering why very few owners follow the book and on top not even being a professional auto mechanics.
Has not the manufacturer made extensive research and finds 100,000 miles to be a well balanced and optimal time to change spark plugs.
Have anyone noticed a change to the truck performance when changing plugs at 100,000K
Have anyone regraded not changing much earlier?
Thank you
HEMI 5.8
I can’t believe it’s Friday and the typical poop storm hasn’t ensued.
Changed the plugs on my 15 Hemi at 100K, did it myself, took my time.. no difference before/after.
They were worn, but zero issues. No difference at idle up to redline.
Here’s the range of reasoning you’ll get.
Backyard mechanics of yesteryear. I change my oil ever 3K, Plugs at 25 or 30K.. and I can still tune a Holley 4 barrel by ear…and can eyeball the air gap for points…
Middle of the road.. double that.. to feel more in a safe zone.
Me…. Meh, keep up with maintenance by the book, close as I can. Changing oil when it tells me to is the most important, but don’t feel the need to spend my money on it any more frequently. I can wipe my rear 4 times, but… 2 is sufficient…
Marketing hype sells product and services.
One thing though… just to be clear. Pro Mechanics didn’t write that maintenance schedule. Engineers did… after it got ran by lawyers and accountants…and probably a few more folks prior to print.
I’m not the guy who is a DIYer anymore. I do like doing brakes though…it’s therapy, always did like doing them.
I’ve worked hard and smart to let someone else do it for me…and pay them accordingly.
Can it be done cheaper? Of course. but time is also money, my time and my money…and I spend it how I see fit.
Mileage is only half the equation, if your vehicle idles a lot, remote starts, heavy towing, etc. the milage doesnt tell the true story of how much wear is on the plugs. A better indicator is the hour meter on the engine.
100k miles on a set of the factory double platinum plugs is non-issue. They are designed for that. That mileage is based more on the spark plug manufacturer suggestion, than any RAM engineer. Will not hurt to change early, not at all, but it also won't benefit you in any way
GM moved to 100k mile plug change back in the 90's and depending on some variables that is okay. that became a thing with fuel injection and a computer the engine.
It's more due to difference in plug design than the engines.
100% use copper plugs vs platinum or iridium and you will need to change them more often. i went with NGK Ruthenium.
I did mine at 72k just can't go 100k, .
Changed mine at 90k and afterwards start up was faster (less of a struggle) and I FEEL it runs smoother. mine were fouled pretty bad!
Changed mine at 155k miles. I started to notice a little misfire or hiccup when going full throttle. Anything less than full throttle, it was undetectable. I knew I was way overdue for plugs. Had the dealer change them and all was back to normal at full throttle. Drove the truck another 50+K miles before trading it in for a 2025.
I’m at 95k, today i swapped the front diff fluid, the Transfer case fluid
And did the Ppe pan swap and breaks as well because I’m going on a trip and will pass 100k on it.
I bought spark plugs but i think im gonna ride them out on the vacation until i get back.
The oils looked fine but i fell better about swapping them, although i do wanna recheck the level and i keep checking for leaks lol.
My wife has a GC w the 8 speed it’s at 135k w no fluid change and it’s been smooth.
I got my truck at 85k though, so that’s 85k i can only tell so much from Carfax, doesn’t tell me if the last owner was tough on it or not.
  • Like
Reactions: RHO
