bigoldthor
Mine doesn't have the auto-start/stop (let's call it "A$$") feature, which is fine.  I had it on my 2017 F150 and had mixed feelings about it.  However, Ford says (and I assume other manufacturers do the same) it had a heavy-duty starter and battery to compensate for the extra A$$ cycles.
My question is about doing it myself at what I know will be long stoplights (or other long-idle traffic events.) How hard is this on the regular battery and starter? I doubt mine are considered "heavy duty" since it doesn't have the A$$ functionality. Are there other factors/systems to consider besides these two? I'm not doing this very often but if it's going to be more than, say, 20-30 seconds, I consider it. Let's call it 1-2 times/day.
I saw (I think) on Engineering Explained where, roughly speaking, you start saving money after 7-8 seconds of A$$. That is, you'll use more gas restarting your vehicle than you would at idle for up to 7-8 seconds, after which it's better not to have been idling during that time. This number was calculated using something like a standard Toyota (or Honda?) 2.4L under controlled conditions, so YMMV (literally and figuratively).
