LT Rated Tires
P4273
Hey everyone — I recently picked up a 2023 RAM 1500 Laramie, and it originally came with what I believe were cheaper P-rated tires that I ran at about 39 PSI. I just switched to BFG KO3s in the stock size, load rating d but went with the LT version. Belle Tire set them to 39 PSI cold, but I’ve been reading that LT tires usually need higher pressure. BFG’s site mentions around 50 PSI, and an online calculator put me closer to 48 PSI.
Just wanted to confirm if that sounds right and whether I should bump the pressure up even when the truck is empty. Also, if anyone else is running Lt KO3s, what PSI are you running day-to-day?
After using combined methods of chalk test and monitoring tire wear I have the rear at 30 and front at 40 when unloaded. I found this to be the case with Michelin Defender and current set of Cooper AT3, both 275/70 r18 E rated
That's crazy. I run my AT3's at 48 front, 40 rear. I usually get 55-60k miles out of my tires. The stock Rebel settings for the Duratracs were 55 front, 45 rear, but that not only felt rough it wore the centers of the tires.
