Looking to add a couple subs with the built in amplifier
Gobie1971
I already replaced all the factory speakers in my 2020 ram 1500 crew cab. I am looking at adding a couple JBL 8” subs with the amplifier. Was wanting to know which wires to hook into from the anc amplifier. Any help with this would be appreciated
Here you go - most people use the ANC bypass harness (including myself), or clip/unpin the ANC mic wires as adding bass can cause unpredictable results. Ultimately you are looking for the Rear right & Rear left channels coming out of the radio (assuming you're on the Base 6 and not the Alpine) - good luck!
