Just below it's capacity doesn't mean it will do well. He'd be much better off getting the 3.92 because he's towing in the mountains.That's well below the 8,000 lb towning capacity of the 3.21 trucks. You should be fine.
Ummm....it's an 8 speedI own a 5.7 with 3:21 axels in fact I ordered it that way. I tow a rv just under 6000# and live in the Denver area. When I take the rv. it is usually to the west over Loveland pass and long 6% grades so I feel qualified to answer your gestation. So here's the deal, the transmission being a 7 speed will not let the engine lug it just goes down in gears to give you the speed you want and when you get to flat land it goes up in gears to give you what you want. That is the beauty of 7 gears, gear 6 and 7 are overdrive gears you will never see those gears while towing, but when not towing the truck will go into the overdrive gears to give better gas millage and less wear
Yep. LOLIm
He's "qualified" though.......Yep. LOL
6,7,8 whatever. The point is it will work. Is it ideal, no, the 3.92 is better suited. The op said only occasional use. As long as he’s ok climbing the pass slower than bombing along at turbodiesel speeds he will get where he wants to go.He's "qualified" though.......
I pull a 6,000lb boat with 3.21 and it does just fine. Never have much trouble with it. Just got a bigger boat so upgrading to a 2500.Looking at used 2019+ Ram 1500 hemi 4x4's to occasionally tow a 6000 lb travel trailer in the mountains. Most have 3.21 axle, will that work?
How much bigger? While I agree that a 2500 is a better tow platform, not too many owners would make that switch unless adding substantial weight.I pull a 6,000lb boat with 3.21 and it does just fine. Never have much trouble with it. Just got a bigger boat so upgrading to a 2500.
