gomango392
Updated my rear suspension. My Cargomaxx post gained a ton of popularity and although they worked good, after about a year of using them, I noticed they weren't doing as good of a job anymore and the truck was starting to sag just about as much as before the springs.
This system here is the be all end all. I was never a fan of bags as I am more of a set it and forget it guy but this system has changed my thoughts on airbags. It's an extremely simple system so not a ton to go wrong, lifetime warranty on the bags, the on board air management system allows for seamless height adjustments on the fly and best of all is the incredible ride both loaded and unloaded.
The ability to lower the rear all the way down to the bump stops and air back up to ride height in less than 20 seconds is awesome. Makes for loading and unloading of the bed a breeze, plus you can mess with the guys at the mulch and stone yard
You will not find a better rear suspension system than this kit here!
hpbuilt.shop
LOGIQ 2009+ RAM 1500 - Air Spring Kit Coil replacement Primary Air Suspension
Coil replacement Primary Air Suspension for RAM 1500. Smoother ride, heavy-duty load support, and extended travel. Upgrade your RAM 1500 with LOGIQ’s Air Spring Kit—a coil replacement solution that swaps factory coils (or factory air) for primary air at the rear axle. Enjoy a smoother ride...
hpbuilt.shop
