My_first_RAM
- Aug 16, 2020
So I am swapping out the square LEDs on my go rhino sport rack 2.0. All of the wiring is there, but I am trying to make this as easy as possible. I am installing 4 rigid cube spotlights with the standard plug. What is the best option here? Should I cut the plugs off and just solder each of them together (1 to 1 to 1 to 1 to the plug/switch cable)?
Or is there a 4 to one connector that I should buy? Connect them all together and then go into a single clamp plug?
many help is greatly appreciated.
