Michael_D
- Jun 22, 2018
I'm hopeful that someone, or maybe several on this site may have the answers to a couple of questions I have.
I've been searching this site to get some info on light bar installs and how to configure the switching functions. There does not seem to be a good DIY guide to be found. I am particularly interested in how to use the high beams as a trigger, options for mounting a bar in the bumper, options for mounting one behind the grill, switch options for the dash that look OEM, and the brand of light to purchase.
This thread in the "interior" board is about the only one that speaks to using the high beams as a trigger. (Switch install on dash for light bar)
I cut the wire that leads into the relay as the trigger, and hook that up to my trigger source. On my old truck that was using a add-a-fuse to the high beam circuit in the fuse box, on this truck that was tapping into the wiring for the driver side high...
I have a 2022 limited. A moment of stupidity necessitated a need for a new front bumper. I bought a new bumper, painted it, and now plan to get some PPF and install that after the new paint has a couple weeks to cure. I figured this is the optimal time to install a light bar, assuming I install it in the bumper. I thought the RC bar would be a slam dunk, but it comes with a standard wiring harness that uses a toggle to turn it on/off. I'm also a bit concerned it may not have enough light output.
I believe these newer trucks power and switch lights through the BCM, and if the computer senses too high of a current draw, it opens the circuit. I have been advised that simply cutting into the high beam wiring to trigger a relay, may result in faults. Is this a valid concern?
I understand that there is a preference for the offroaders to install an external switching panel, like the Auxbeam BA80 Switch Panel Kit, or they more expensive Switch-Pros 9100. I have no desire to run additional lights or accessories, just one light.
As mentioned earlier, I am unsure if the 20" RC light will have the reach I am looking for. I am hoping to improve long-range lighting to see large critters (moose) before they jump onto the road. I think I can fit a 32" bar in the bumper, but am unsure if a larger light, placed behind the bumper insert, would work well enough? I'm also not real clear on bracket options for mounting one. Are there brackets for this type of installation readily available?
With all the hardware and louvers behind the grill on these trucks, can a light bar be mounted behind the grill, and also mounted in a way that actually looks good?
Used a regular light bar wiring harness with a relay and wired direct to the battery. I dont like having to find a small switch to turn the bar on/off so I want it to my high beams.How did you wire into your high beams?
I've got trigger4 system and I hate the switching. Would rather wire my light bar to the high beams and be done.
