Lifting a 2025 RAM with factory raised ride height
D_Rud
Hello, I want to lift my 2025 RAM 1500 Bighorn with the factory raised ride height. I looked at rough country and readylift and the both state with their 3.5" lift that it isn't compatible with the factory raised height? Is this the same as the 1" from factory? I'm looking at my window sticker and my truck has extra heavy duty shocks with the raised ride height. I called rough country and they said their 3.5" lift will not work and the have no other product to lift or level. I called readylift and they just said to measure and didn't know for sure.
1) How can I lift my truck with the factory specs 3.5 to 4" Is the Bilstein 5100 the best option? I would like to get close to 35" tires with 11.5 to 12.5 width on 9x20" wheels with the proper offset/backspacing so doesn't rub
is anyone else running into this issue? Suggestions? Thanks.
Or maybe I can ask the question better. Who has a 2025 RAM 1500 with the factory extra heavy duty shocks front and rear with the raised ride height? What lift did you go with and what tire wheel combo worked? Pics? Thanks
It'll sorta be the same as 19-24, BUT the engine weight difference might make the lift height different. Wheels will definitely be the same as 19-24 for fitting w/wo lift.
Does your truck have the factory raised ride height?
