Leveled with WDH and airbags?
DOFF
I’m sure this has been answered a ton but my eyes hurt from reading through all the previous threads. So thanks in advance for any help.
Finally pulled the trigger on a 24ft travel trailer I pick up Wednesday. Dry weight of 5400, tongue weight 500. I have the bilstein 6112s up front with 5100s rear and a 1” rear block for a total rake of 0.5 inches with tow package. They’re throwing on a weight distribution hitch for me. Question is, due to my stance, will I need airbags to re level the truck? Or will the WDH redistribute the weight and relieve the sag? And if I go with the airbags after the wdh is installed, does the hitch have to be reconfigured or anything else?
Trying my best to prep ahead of time.
Thanks for the help!
You need to inflate the air bags first then set the WDH for a proper setup. So yes you would need to reconfigure the WDH if you add air bags after the initial setup
Figured that’d be the case. Thanks for the help.
