Level or lift
Shark875
If you level or lift make sure to replace your stabilizer bar links, The factory set is junk and with the extra space they will wear fast as mine did! 18,000 miles. Upgraded to the suspension Maxx bar links and it actually rides better then new, solid and tight zero clucking or noise! look at the old ones you can see the boot is absolutely wasted already. Took me about 1.5 hours to install and get everything tightened back to specs. overall easy installation.
