Bay Area RAM
- May 26, 2019
Had the truck in OR1 with a heavy duty dump trailer in tow. Had to 4 wheel into where I was gonna load it and needed a little additional clearance..... didn't take the truck out of OR1 and after loading the trailer I was unable to adjust any air ride settings back to normal and got the payload error. I'm thinking the payload error is more sensitive if you start in OR1 rather than 'normal'.
Once I was clear of the need for clearance I had to disconnect the trailer completely and drive the truck around the block for the computer to allow me to get back to the 'normal' suspension setting. Then I hooked the trailer back up with no issues.....
Lesson learned..... heavy loads should only be done in the 'normal' setting.
