LED tail lights
pbclax1
Does anyone know if the black led tail light with the blind spot and the black led tail light without the blind spot are the same? Basically the only difference is the blind spot module that can be removed and otherwise they are identical lights?
Black w/LED w/Blind Spot. Right side part number: 68262532AG
Black w/LED without Blind Spot. Right side part number: 55112992AD
Obviously different part numbers and different costs. But, use the pictures to decide if what you are looking to do is possible (y).
I would imagine they use the same connector with more or less pins attached, depending on which you get.
Yeah I’m pretty sure they’re identical. I was more questioning the lenses being identical along with me just being able to remove the blind spot module. Thanks!
Why not just activate the blind spot monitoring system if you have lights with the modules? These lights are horrendously expensive. I just had to replace one. Dealer price for one light with sensor was $834, I found one at $550 online. It's a slick feature to have, especially when towing.
Wiring is different from 2019 to 2020. What year are you asking about @pbclax1?
I don’t have the blind spot in the truck so I would remove the module out of the one since the other led i got is non blind spot
Billet Laramie - it would be a 19
Lol it was kind of difficult to put into words. Found a good deal on the RH led taillight. Looking for a LH led and the best deal I could find is a blind spot one which brought up my question
Just trying to see if the exterior makeup of the light is the same coloring, etc
