LED tail light burned out
jgdblue
2022 1500 Laramie. Factory LED driver side tail light burned out, but brake and turn signal work. I removed the tail light and it looks like it’s sealed and difficult to disassemble. Electrical connection looks clean. I assume the whole damn thing has to be replaced? Very disappointing on a truck this new with 67,000 miles. Any aftermarket options that match? Is it an option to change the plug and run regular non-led taillights?
The only option is to replace the assembly. Do you have BSM? If so, then you need the factory LED.
I do have BSM, is there some reason that prevents me from swapping to halogen?
The BSM radar is in the taillights. I'm not 100% sure if the Halogen ones have that.
Get a replacement and transfer your radar module and you good to go.
That looks like a great option. Do you know if it would be a match for the oem passenger side tail light that I have?
Depends of which ones you have. There are 3 different styles. Just select the style you have, make sure they are for BSM.
