Lmfao.... I mean... Sure.... We could build a super computer to see if I’m male or female... But I think it would take less time to just check.
in other words, you would have to monitor the port, break security in the vehicle to see this, then make a program to watch or listen to a port, or signal, and then turn a circuit on... Then off! That’s a bit over the top for most folks.
So do you have fog lamps now?
You could do a few things with relays! First, take the fog light signal and reverse it with a relay to trigger high beam. BUT being you don’t use the fogs all the time, may not work as you want. Yes, the headlamps use a control box to turn off and on the LED lights. They get a can bus signal.
Before using a PI I would check a few things with AlfaOBD. First check to see if programming can be done for an extra output. As I do see that you can program some of these items. 2. Use a relay that triggers off low voltage. (You can find these any place!) you would use 85 and 86 as your trigger. 30 and 87 or 87a would be feed. Depending how you do this. SO, without having a system in front of me, I can’t tell you where to start, but if your local, I’m happy to help!
At some point today, I plan on looking at my truck! Again, I don’t have LED headlamps in mine, but I might be able to see an area in settings for light output.
now, looks like the LED controller is on the headlights themself. I’ll take a look and see if I can find some information.
I’ll be adding some switch back DRL strips, and looming to do some output programming, or tie in.
the Raspberry pi Is a cool idea, but takes some work to really get it right. You would need to be good with electrical, and more. Not saying it’s impossible, but the length you will have to go to get it working, is much more then using a relay and some wires or AlfaOBD.
