LED Help
KingSnake
Greetings all,
I have a 23 Bighorn Night Edition 1500. I have swapped out the low beams with LED bulbs and they are working great. I attempted to swap the fogs, high beams and front turnsignals as well, but none of those have worked. I have searched the forum but do not find a clear answer...are the bulbs I purchased incompatible with the Ram or is it just the setting needing to be changed through Alfaodb? From what I have read, a simple bulb swap should not require reprogramming.
Sure the polarity is correct? Turn the bulbs around and see if that fixes it
I tried that with the turn signal bulbs but no change. The fogs and highs the plug will only fit one way.
I used Lasfit bulbs in all locations of my Big Horn and have zero issues with them. They have a built in resistor for the CANBUS system that Ram uses to monitor voltage to lights. I highly suggest Lasfit. 5 months and no issues.
Lasfit lows/highs and Auxito Fogs with no issues. All plug n play.
What bulbs are you using?
Hikari for the highs/lows & fogs & Auxbeam for the turns. This set up served me well in my Colorado. Not so much on the Ram.
Have not come across Hikari yet on the forums. I have Auxbeam Ditch lights but not an issue. I wired them right in.
Sorry you're having issues.
