Sure, lots of people have added LED backup lights. Use search and you should many threads on it. A lot of people use the trailer harness to power them.I just joined the forum. I have a lot to learn. Can you put Led backup lights in a Ram 1500 that has the merge detectors? Thanks
ThanksSure, lots of people have added LED backup lights. Use search and you should many threads on it. A lot of people use the trailer harness to power them.
Best wishesI just joined the forum. I have a lot to learn. Can you put Led backup lights in a Ram 1500 that has the merge detectors? Thanks
Tapped into the 7 pin with supplied T connectors. 3M taped (supplied) to the bottom of the receiver. Install: -Look at your 7pin and look in behind your...
