Laramie interior upgrade
richards6.7
I have a 2016 Ram 2500 SLT. And have recently put a 2014 Ram 2500 Laramie interior inside: includes power seats, heated/ cooled seats, and rear heated seats. Everything in the center console for charging use is working. Any idea to what has to be done for the seats to function as they’re suppose to?
Any help is Appreciated, Thank you.
I just finished installing 2019 Gen 5 Seats in my 2026 Ram 1500 big horn. If you want the passenger seat to operate and lumbar work connect the 2016 Wire #14 A942 Red Fused + to Red Fused B+ on the 2104 yellow plug Fused B+. The grounds will be black so connect the ground as well
Drivers seat is the same. Use Wire Wire #1 942 Fused B+ will connect to the Red fused B+ on the 14 seats and connect the ground wire as well.
I disconnected my battery to make sure the air bags didn't deploy while I was working.
That was 2016 not 2026.
