Just dropped
2/4 static drop
What do you mean by static drop? I got a maxtrac 2/4 on mine and it runs on the front driver’s wheel side. Does yours?
Static drop is just a term used when you lower a vehicle by springs. Basically no movement up or down like air or hydros.
Do you have the 6'-4" bed? How's the ride and are you bottoming out?
Yeah its the (long) bed the ride of course is a little stiffer. It hits harder on regular bumps than factory but still better than sitting on leaf springs. What do you mean bottom out? Suspension or chassis
I meant if your hitting bump stops. Is it 2/4 from Maxtrac? Looks real nice!
The only time I hit bump stops was going a little to fast over a speed bump. And that was in the back even with the stops cut. And yes it is the 2/4from maxtrac. Little rubbing on right front at full lock and rubbed pretty good last night going through some twisty and loaded left front suspension pretty hard. But it definitely held it when I threw it i to the turns.
