JBA Control Arms
evrider
Does anyone have any experience with these JBA control arms ?
I need to get new tires soon and was looking to upsize to a 285/75R18 and keep the Factory wheels. The control arms do not keep the stock caster and not sure if they interfere with the stock rim offset, but was hoping to find someone with first had experience.
How would tire size change your geometry?
I was referring to the control arm interfering with the stock wheel. I edited my first post as it was not clear. The JBA control arm increases caster and there seems to be comments on their website about it not working with some of the older gen Rams.
A couple weeks ago I installed the JBA upper control arms on my 2024 Rebel. With the stock wheels and tires I had a little over a half inch clearance to the tire from the UCA. No issues at all to the wheel. I bought the UCA version for the lift since I also installed the Eibach coil overs on my truck at the same time. Not sure if that will help. IMG_3449.jpeg
A couple weeks ago I installed the JBA upper control arms on my 2024 Rebel. With the stock wheels and tires I had a little over a half inch clearance to the tire from the UCA. No issues at all to the wheel. I bought the UCA version for the lift since I also installed the Eibach coil overs on my truck at the same time. Not sure if that will help. View attachment 193211
@stevieb92 how has that set up been for you? Would you do the same again?
