Issues with TazerDT--Hoping someone can confirm.
ReLLIK75
I've got a 2019 Rebel with Air Ride. I've been using the TazerDT for a while now, but have finally noticed some odd behaviors that it causes with my truck. When I push on the brake pedal, I get four faint beeps coming from the rear right roof speaker. Also, if I use my keyfob to lower the truck to entry/exit mode, then open/close the tailgate, the truck will get stuck in entry/exit mode and will not automatically lift to normal mode when above 15 MPH.
I took the truck to the dealer last week to have them check these two issues. I left the TazerDT installed because they've never said anything about it when I've had it there for other service issues. They went through a fairly lengthy diagnostic process and finally pinpointed the behavior to my TazerDT. When the unhooked it and reconnected the wires to factory configuration, the beeps and the entry/exit sticking stopped.
Can someone with a TazerDT and air ride confirm the four faint beeps when you press the brakes. Also, to get stuck in entry/exist mode, turn off the truck, use the keyfob to drop in to entry/exit mode, open and close your tailgate. When you start driving, you should stay in entry exit at normal speed until you manually raise it back up.
The keyfob lower sticking in entry is on all the trucks with air. has nothing to do with the taser.
No idea what the beeping is either. None of taser stuff has audio feedback. The only thing i've noticed is that sometimes the tazer will blink a LOT at night and its annoying. It will also blink your interior lights at night if you are using cruise control and hitting resume or cancel. It's something to do with the shortcuts and lightshow, but even with those disabled it will still blink the puddle lights for a second.
Is there a TSB for the entry/exit mode sticking issue? The beeping noise is consistent and very easy to reproduce. It happens EVERY time I press the brakes. And sound is only emitted from the one speaker.
No TSB. Just experience https://5thgenrams.com/community/threads/air-ride-stays-in-entry-exit-while-driving.25985/
Did you email Z automotive? I had an issue with mine being one of the first 2020's being unable to marry and I had an engineer on the phone and sending videos back and forth in minutes and a fix in a day or two. They are pretty good about fixing things.
I have emailed them. Haven't heard back from them yet.
