Instrument Cluster Sun Glare -- Solved
CBH
I was driving my ’23 Ram Rebel at noon (sun high overhead) and couldn’t read the MPH numbers in the center of the instrument cluster due to excessive glare caused by the sun’s rays reflecting off the shiny plastic steering column housing. I found a quick (and probably permanent) fix -- I laid down two strips of adhesive-backed black felt on to the top of the steering column housing -- the glare is gone -- problem solved.Dash Glare.jpg toptop
I was driving my ’23 Ram Rebel at noon (sun high overhead) and couldn’t read the MPH numbers in the center of the instrument cluster due to excessive glare caused by the sun’s rays reflecting off the shiny plastic steering column housing. I found a quick (and probably permanent) fix -- I laid down two strips of adhesive-backed black felt on to the top of the steering column housing -- the glare is gone -- problem solved.View attachment 161857 toptop
You just need to wait until some dust builds up, blocking that glare.:ROFLMAO:
